View Full Version : Anyone using small carbide saw blades on mill ?
nheng
01-25-2009, 01:44 PM
I noticed some 4-3/8" carbide blades with FTG tooth profile (flat top grind) for small circular saws and was wondering if anyone uses them on their mill for (somewhat) precisely cutting off aluminum parts with large cross sections. They seem fairly low cost compared to carbide slitting or slotting saws. Den
Timleech
01-25-2009, 01:52 PM
I noticed some 4-3/8" carbide blades with FTG grind for small circular saws and was wondering if anyone uses them on their mill for (somewhat) precisely cutting off aluminum parts with large cross sections. They seem fairly low cost compared to carbide slitting or slotting saws. Den
ISTR there was a thread about this a while ago, not tried it myself.
What's FTG grind?
Tim
nheng
01-25-2009, 02:01 PM
FTG is a flat top grind where the top of each tooth is flat. The more common grind is alternate top bevel, or ATB. I would think that the ATB might chip easily due to the sharp angled points, or maybe create some side force.
Timleech
01-25-2009, 02:07 PM
Makes sense
So it's really FT grind ? ;)
Tim
nheng
01-25-2009, 02:11 PM
I'm slow today. It's been edited ;)
jstinem
01-25-2009, 09:31 PM
I've used ordinary Skilsaw blades to cut Al on the Mill. They work great. Just do the math to get tip speed right for the metal you are cutting.
Joe
DICKEYBIRD
01-25-2009, 09:44 PM
Den, here's a pic of mine; it works great! It has a homemade arbor with a 3/4 shaft. I just used it last weekend and kept going up on the d.o.c. and speed. I stopped at .5 in @ 800 rpm in 6061 in my little X3. Much better than any of my regular slitting saws. Mine is 3 3/8 dia and it looks like it has the FTG grind you refer to. I haven't used a 'normal' slitting saw since getting this one over a year ago.
http://i57.photobucket.com/albums/g227/DBAviation/SawArbor3sm-2-1.jpg
http://i57.photobucket.com/albums/g227/DBAviation/SawArbor3sm.jpg
saltmine
01-25-2009, 11:01 PM
I've used them quite a bit. Sure beats buying slitting saws and such....Of course, I did have to make an arbor for the ones I have...
Feed it slow, or it'll start shedding teeth, though. And lots of lube...
I've even sawed through hot and cold rolled steel with mine.
