View Full Version : A light for 20 ga. 870
Boucher
02-03-2009, 07:40 PM
The Armadillos are rooting up our yard like a herd of Ferrell hogs. The wife has been going on armed patrols throughout the night. She can break 25 straight at Skeet but she can’t hold a light and shoot very well. I have a couple of lights that mount on a scope they are both in need of repair. Been thinking of using the plug space in the magazine tube for batteries and attaching a light to the magazine cap. Suggestions and recommendations would be appreciated.
davidh
02-03-2009, 09:20 PM
i suppose this is too big, but i have this exact light and its awsome bright and lasts a long time with a charge, plus you can leave it onl the charger all the time if you use it once in a while. my boy has taped it on the bottom of his deer rifle (oops), i mean 22 ruger. . .
http://www.magliteoutlet.com/?gclid=CI-JktDzwZgCFRlcagodrjoF2w
huntinguy
02-04-2009, 07:00 AM
http://www.cabelas.com/cabelas/en/templates/product/standard-item.jsp?_DARGS=/cabelas/en/common/catalog/item-link.jsp_A&_DAV=&id=0005772223328a&navCount=0&podId=0005772&parentId=&masterpathid=&navAction=push&catalogCode=IJ&rid=&parentType=&indexId=&cmCat=netcon&cm_ven=netcon&cm_cat=Google&cm_pla=tacstar%20light&cm_ite=netcon&rid=0180101070502&hasJS=true
bj139
02-06-2009, 05:15 PM
I think I have seen something like this in brass or copper in the plumbing supply section at the home center. It should be quite a bit cheaper and brass or copper should not scratch the barrel (I guess). This might work. http://www.pexsupply.com/categories.asp?cID=727&brandid=
vBulletin v3.5.4, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
