View Full Version : Useful as Parallels
Dunc
02-04-2009, 09:09 AM
Was in Lee Valley store (Canada) the other day and noticed this set of a 1-2-3 block and some anodized aluminum bars.
http://www.leevalley.com/wood/page.aspx?c=2&p=45089&cat=1,240,41064
There is only a single bar of each size. If I purchased 2 sets would the pair of, for eg, the 1/2-inch square ones act as a pair of parallels? Or, as I suspect, might I get - by random selection - one bar with the + tolerance and the other with the minus? Any way to determine?
Just a bad idea?
Circlip
02-04-2009, 09:18 AM
Did you ever check two pieces of ground HSS tool blanks from the SAME batch?? And tough as anodised Alumininininium may seem, it won't take a beating.
Regards Ian.
tony ennis
02-04-2009, 09:22 AM
Is 'Veritas' engraved into the face of those aluminum bar thingies? Just what you need - engraving on something that's supposed to be flat and smooth.
tony ennis
02-04-2009, 09:30 AM
These ChiCom parallels (http://www.use-enco.com/CGI/INSRIT?PMAKA=630-4257&PMPXNO=945646&PARTPG=INLMK3) are cheaper than the Veritas product and claim to be more accurate at +-.0008".
Each pair potentially being off by up to .0016 seems like a lot since these are set-up tools.
rowbare
02-04-2009, 01:11 PM
<snip>
Yes but these are meant to set up woodworking tools so I think the accuracy is quite adequate.
Timleech
02-04-2009, 01:16 PM
Regards Ian.
In my experience they're not always even flat, never mind parallel (or square, if 'square' toolbits)
Tim
