View Full Version : Bolt fluting/engraving CNC Pick Heavy
sdeering
02-05-2009, 12:02 AM
Just set up the 10" rotary axis on my old bridgeport series 1 conversion. Runs on Mach3. I was unsure of the bolt hardness so I was running a little on the slow side.
http://img.photobucket.com/albums/v510/sdeering/DSC00019.jpg
http://img.photobucket.com/albums/v510/sdeering/DSC00026.jpg
http://img.photobucket.com/albums/v510/sdeering/DSC00022.jpg
Test run on some aluminum, engraving was ment for 1.25 so it looks a little wide. Will be engraved on a barrel.
http://img.photobucket.com/albums/v510/sdeering/MVC-014F.jpg
Vid
http://www.youtube.com/watch?v=etWwUIy1RUs
Enjoy
Stephen
RPease
02-05-2009, 01:31 PM
Just for my own curiousity.........why would one flute a rifle bolt??
1. I can see to reduce weight........although I would guess the weight reduction is minimal (I suppose every little bit helps).
2. Maybe it would help reduce friction between bolt and receiver housing.........but wouldn't it just make a whole lot of pockets for dirt and grit to collect in?
sdeering
02-05-2009, 02:14 PM
I really don't think there is a physical benefit. Sure looks cool though.
There have been some people in my area that want this done, so I am about to take on some work.
Stephen
rdesign
02-05-2009, 04:38 PM
Cool, that really makes me want to get a 4th axis set up on my machine.
RPease
02-05-2009, 11:28 PM
I will admit that it looks good. Just wondered about the usefullness of it. Good luck with the projects..........
Regards.............Rodg
rbertalotto
02-06-2009, 06:32 AM
A little less weight and a real big "cool" factor............:D
You should offer this service. Many folks would use it.
rws
02-06-2009, 12:54 PM
Many people feel a fluted bolt is smoother since it has less drag/surface area. Stolle has been doing it for years a standard practice. Most all the custom actions now have it at least as an option.
Very nice work BTW.
HTRN
02-10-2009, 09:32 AM
The reason for bolt fluting, at least on BR actions, is to give any dirt someplace to go, in order to prevent bolt bind. Remember, typical clearance on a benchrest action is in the .001-.0015 range, vs. .008 or so on average for a Remington 700.
Then the high end makers of push feed guns like Lazzeroni started making guns with it, then it became a trend.:D
HTRN
john917v
02-10-2009, 11:19 PM
Friction, dirt-channeling, and the bolt-flutes hold grease.
Sdeering, that is some nice work! I'd love to have my 917v bolt fluted.
I'm planning a mag. opening-plug and top-mount brace/scope mount to stiffen the action up a bit on mine.
sdeering
02-11-2009, 03:44 PM
Thanks for the replys fellas. I should be getting the first shipment of bolts to flute soon. I have a 6mm barrel being made for a new 6mmBR project. When I get it engraved I will post some picks.
Stephen
