Does anyone own or have a working knowledge of this Semi-Universal Dividing Head? I've purchased a new B-0 model and instruction manual is not written well and I need some help.
Harold
For those having fought for it, Freedomhas a flavor the protected will never know. Freedom is only one generation away from extinction.
There is quite a bit in Machinery's Handbook about doing dividing.
I have a Vertex model which appears Identical, I have used it to generate Square & Hex ends on round components and also for gear cutting, what do you need to know?
Regards,
Nick
Harold, (or others)
PM me with your email address and I will send a number of files that I have saved and that you will find useful, including instructions.
I would post the links but all that was saved were the files.
Mine was of very poor quality, paid $300 new for it. What I did to improve it was to mesh the worm tight, then attach a drill motor to the crank shaft and let it spin and spin. Tighten the mesh and spin again. After a few hours most of the backlash was gone.
The holes in the index plate are another matter - some are .020" off from the others. It will take considerable time to replace these. There is an inherent error correction - it's split 40:1 and doesn't cause problems on small work, so the incentive to fix these is low.
Using the head is simple fractions. divisions/40 and finding a hole plate that works out to support the remainder. If the remainder is 5/7, that would equal 25/35 or 25 holes on the 35 hole circle.
First light has yet to come to Alaska and already many have responded to this post. I thank you!!
Here is my question ....... and problem. Most dividing heads have "neutral gear". When in neutral gear one can freely rotate the work without having to use the hand crank. I cannot seem to find any instruction in the manual regarding "neutral gear". Does this unit have "neutral" and if so, how do I engage neutral?
Thanks Guys.
Harold
Wide selection of tooling and accessories for the manufacturing and metalworking industries. We offer quality inspection, measuring, cutting, power, and hand tools.
I have always been under the impression that a universal dividing head had gears or some other provision for it to be driven off a power table feed enabling it to cut a spiral or helical gear.
Gears on a universal dividing head are also used to make divisions not achievable by just using index plates. Divisions like 51, 53,57,59,51,63 etc, etc..
These have to be geared so you gain or lose one tooth by the time you make 40 cuts. You have to remove the index pin holding the index plate steady. It can be pushed in and locked. Now your plate being geared to the main dividing head spindle will advance slightly or retract slightly to compensate for the one tooth.
Loved the old No.2 B&S Universal Mill together with the B&S Universal Dividing Head. And yes - with a Universal Dividing Head you should have a Universal Mill. Good way to cut spirals.
