View Full Version : D.I.Y. On the truck rotor machining
digger_doug
02-26-2009, 11:33 AM
http://i275.photobucket.com/albums/jj300/digger_doug/rotor-machining-005.jpg
See if I can get the 'putor to work...
Harbor Freight tools at their finest.
Circlip
02-26-2009, 11:42 AM
That saves one h*ll of a lot of skinned knuckles and broken disc retaining bolts.
Regards Ian.
Timleech
02-26-2009, 11:45 AM
I trued up a big marine gearbox coupling flange a few months ago, using a small bench grinder mounted on one of those XY vices. Bench grinder was a bad choice, painfully slow, I reckon an angle grinder would have done a good enough job in a quarter of the time.
Sadly don't have any pics, someone else took some but I've never seen them.I'll ask next time I see him.
Tim
rockrat
02-26-2009, 12:15 PM
I was waiting in line at Napa the other day and was flipping around in the catalog that they had there. But they sell a setup kinda similar to that. Theirs was $7k? Yours looks cheaper and probably works better. Nice job.
How did they turn out (no pun intended)? Did you use a little grinder or is there a tool bit there? The photo is a bit small and I cant find my glasses.
rock~
digger_doug
02-26-2009, 12:21 PM
"But they sell a setup kinda similar to that. Theirs was $7k? Yours looks cheaper and probably works better"
Well, it was definitly cheaper, but the store bought units
(I believe) are built to be universal, to fit most everything.
I felt that a lathe tool would require more ridigity than I could muster,
so hence the slower, but easier grinding wheel.
Cost's:
1. x-y cross slide vice-H.F. special $40
2. Die grinder-H.F. special $20
3. Motor (1/4 h.p. 1140 rpm)-scrounge
4. Brackets-scrounge & weld
Hogridnfool
02-26-2009, 08:29 PM
Rockrat,
Hold your Ctrl key down while you work the scroll wheel on your mouse, that will expand the photo so you can see the detail in what dirty doug did to build his rotor grinder.
Digger doug,
How is your device attached to the vehicle?
Carld
02-26-2009, 10:16 PM
That's crafty as all get out digger :cool: How did you go about getting it lined up with the surface to cut it straight across? A dial indicator?
CCWKen
02-26-2009, 10:44 PM
Did I hear someone mention carnival ride? :D
Ingenious but I'm with Carl--How do you monitor the parallelism of the rotor? I've not known the HF cross vise to move in straight lines perpendicular to each axis. At least the two I have don't. :eek:
Peter.
02-27-2009, 02:44 AM
I think it wouldn't matter much once the pads bedded-in, so long as the disc was running true.
luthor
02-27-2009, 05:59 AM
Doug how did they come out? Can you post some figures on TIR, DTV etc.
Weston Bye
02-27-2009, 06:29 AM
My dad once used a similar setup to resurface the cable drum clutch and brake drums on a couple of Bay City backhoes. The slide was originally a motor mount for belt tensioning. Dad was an excellent crane and backhoe operator and understood mechanics, but his early metalworking skills were limited to the skillful use of the gas axe. Still, he produced excellent results grinding the drums with his cobbled together setup.
spkrman15
02-27-2009, 07:24 AM
Great idea. You get bonus points for doing it in the snow!
Rob :)
digger_doug
03-02-2009, 08:54 AM
"Doug how did they come out? Can you post some figures on TIR, DTV etc."
Well, I only did the one side (driver's side).
It is smooth, and doesn't pulse the pedal at all now.
Did I mention it was maybe 15 f ? outside, on the top of
a large hill, with a stiff (english call it a lazy) breeze ?
No, I didn't check the t.i.r., I will next time, and work more on
the finish, need a harder, skinnier wheel. for less wear,
and skinnier for less tool pressure.
It was basically get it done, and pull the %^$#! fixture off
as soon as possible, to get out of the %%$#$@#! cold,
get the caliper and tire back on, and get the truck ready
for a friday vacation day to haul a lathe.
Mission accomplished, cleveland to erie, 10,500 lbs
on trailer...W&S 1AB.
jimmstruk
03-02-2009, 09:48 AM
Now we need pictures of the lathe. JIM
