View Full Version : A portable drilling/milling head project
S_J_H
03-01-2009, 03:00 PM
I just finished this project. It is of course a small drilling and milling head with a rack and pinion quill. The motor is from a mini lathe.
The housing was taken from an old cheap import drill press. I cut it down and boxed it in. Then indicated the quill dead level and flycut the mounting surface.
It originally had a mt2 tapered spindle.
I made a new spindle out of some 1144 stress proof. It is a 3/8" end mill holder type spindle.
The spindle has 1 bearing at each end of the quill cartridge and I added a bearing preload nut. The splined drive has 2 bearings.
I built this unit primarily for my HBM/lathe machine.
http://i109.photobucket.com/albums/n48/S_J_H/Horizontal%20boring%20mill/portablemilldrill004.jpg
http://i109.photobucket.com/albums/n48/S_J_H/Horizontal%20boring%20mill/portablemilldrill002.jpg
http://i109.photobucket.com/albums/n48/S_J_H/Horizontal%20boring%20mill/portablemilldrill001.jpg
Alistair Hosie
03-01-2009, 03:09 PM
interesting looking project well done regards Alistair
lazlo
03-01-2009, 03:31 PM
Nice job Steve. Is that Hammerite-brand metal flake paint you're using?
S_J_H
03-01-2009, 03:40 PM
Thanks guys,
Yes, blue hammerite. I like this paint. Touching up chipped areas is practically invisible with this stuff.
PHiers
03-01-2009, 04:05 PM
Very nice work. I keep thinking I should tackle something like this someday.
oil mac
03-01-2009, 06:24 PM
Steve,
Your project on this little horizontal boring mill, is most exemplary in finish in your excellent design and thinking You have "shrunk the best of heavy engineering practice", down to the home workshop fraternity, That in conjunction with your milling & drilling head, gives you a most useful machine tool, I think we all envy your talent Very well done.
knedvecki
03-01-2009, 09:25 PM
Nicely done. Thank you for posting the pictures. I have proposed plans to mount my Barker Mill Column to lathe's carriage T-slots with a slide to move in the Y axis. This would allow me to machine flats and spirals and indexing using the gearing on parts mounted between centers up to 8 ft long
Teenage_Machinist
03-01-2009, 09:39 PM
Nice work. One idea thouh, looks like the motor might collide with various things unless rotated the other way.
S_J_H
03-01-2009, 11:52 PM
Thanks again guys. I plan on doing a future thread showing everything the machine can do.
I can see how you thought that in the first pics. The motor is totally out of the way of everything.
Here are some better pics showing the milling head. I have a preset z-axis stop on the main column for repeatable lathe work/tooling. The milling head is on center to that stop. It can be mounted at any angle without interference. The quill has 2" of travel as well.
http://i109.photobucket.com/albums/n48/S_J_H/portablemilldrill006.jpg
http://i109.photobucket.com/albums/n48/S_J_H/portablemilldrill009.jpg
Teenage_Machinist
03-02-2009, 12:01 AM
That is... better than I thought.
If I were building my own, I would move both motors, but that does not appear neccesary.
Your Old Dog
03-02-2009, 07:02 AM
Nice job. Did I mention I got my plastic light mounted on my mill? :D It's plain to see I'm running with the big dogs here and it's getting harder and harder to keep up. Seen a lot of talent on this board the past few months.
davidfe
03-04-2009, 10:09 AM
OD,
Here is one I just picked up from HD.
http://i115.photobucket.com/albums/n319/davidfe/LEDLamp.jpg
It is all LED and really bright. Would work extremely well on a machine tool.
David
dian
01-28-2013, 01:22 PM
i just found this thread, wow, but it is too much. can anybody explain what that is and what it does? headstock and (kind of) tailstock move up and down independently? rigidity doesnt seem to be a strong point.
RussZHC
01-28-2013, 02:44 PM
Where is the green emoticon when you need it ?
I'd settle for a tiny fraction of the engineering and machining skill you have...hey, a tiny fraction of either one of those would be good already.
