View Full Version : M Thread Question re Major Diameter
Bruce Griffing
03-07-2009, 02:05 PM
I am probably missing this in Machinery's Handbook, but I am confused about the major diameter for a metric M thread. I am making an ER-11 Collet chuck on the end of a spindle. The ER11 spec calls for and M14x.75 thread. What I have not been able to figure out is this - what major diameter (diameter of starting material in this case) is implied by this spec. For a 7/8 thread depth, I will need to cut 22.4 thousands deep - but I need the starting diameter to proceed.
Peter N
03-07-2009, 02:13 PM
Bruce, the clue is in the description. An M14 thread is 14mm (major) diameter.
However, I don't understand the 7/8 bit you're referring to on this?
Peter
Bruce Griffing
03-07-2009, 02:23 PM
I was not sure if the 14 referred to the pitch diameter or the major diameter. The 7/8 is pretty standard - you cut to 7/8 the depth of a full depth thread. This leaves the crests flat and less sharp.
Peter N
03-07-2009, 02:27 PM
Ah! I see. I thought for some reason you were confusing 7/8" with 14mm :D
Peter
Bruce Griffing
03-07-2009, 02:38 PM
I just measured a cheap import ER11 chuck. The major diameter on the collet nut threads is 13.88mm. That said - it is a pretty poor looking thread. But I stull wonder if a 14mm major diameter is really the correct answer to this question.
Peter N
03-07-2009, 02:52 PM
It is.
The nominal diameter for all metric threads is designated by the number immediately after the 'M'. If you're talking about class of fit that's another matter.
Peter
mbensema
03-07-2009, 03:02 PM
this page has what you need for the threads.
http://mdmetric.com/pdf/Thdfrm3.pdf
Dr. Rob
03-08-2009, 11:02 AM
You're on the right track, Bruce.
The link above is good info.
Y'see, the M14 designation is true in that the nominal diameter is as others have said, 14 mm. However, an M thread form has 1/8 of the triangle chopped off top and bottom, which means that a proper M14 thread will in fact have a diameter of 13.9-ish mm.
Which entails that if you use a sharpened (pointed, full form 60) vee tool, the thread won't be quite right. Or, it will if you do the full thread, but chop off the 1/8 of the triangle afterwards. That oughta do it.
Which doesn't answer your question entirely, but at least tells you that your question has merit.
Regretful edit later, after a potful of morning coffee:
Nononono, i confused myself. The diameter is indeed 14 mm, but the 1/8 has already been chopped off. So you only need to take into account the 7/8 , and the piece at the root of the thread.
