View Full Version : atlas shaper opps hub with bearing
Brett
03-12-2009, 12:31 AM
So all you smart shaper guys, how do I get the hub with bearing cone part number s7-13a out. You can fiend it on google books. It looks like I press it out; but If I did it mite brack. Any thoughts
03-12-2009, 12:37 AM
The bull gear has to come off it, and then it comes out through the door, after a LOT of things come off the shaper. All of the stuff on the S7-1A comes off, along with the outer bearing, which can be a real pain to remove.
if you are going to replace the bearing cone, you will probably have to split it. it was shrunk on.
Brett
03-12-2009, 12:41 AM
SO how do I split it or will it press out Brett Thanks
03-12-2009, 12:47 AM
You gotta get the assembly OUT first........
Then you can use a Dremel with thin cutoff wheel to groove the old bearing. When the groove gets deep it will probably crack by itself. Mine did.
You can't press it off, because you can't get behind it.
Brett
03-12-2009, 01:11 AM
That sounds great,but mine wont get apart s7-11a is stuck to s7-13a that is the problem it wont come out of s7-11a. So do you think I could split it. Brett
dp
03-12-2009, 01:57 AM
I presume you've removed housing S7-25D and all its parts, and shaft S7-58 and it's parts. That should leave just the S7-11A flange with the S7-171A bearing in it.
Sleeve S7-71A passes through outer bearing S7-171A. Is that loose or is S7-71A stuck in the outer bearing? You may need something like this to push that shaft through the outer bearing:
http://yhst-13811118617756.stores.yahoo.net/otc-1023.html?productid=otc-1023&channelid=BCOME
The jaws would clamp on the rim of the flange, and a bushing of some kind would be needed to protect the S7-71A sleeve from damage by the puller. Or you could make a bushing and use a dead blow hammer to drive it out. I'd try the puller first.
03-12-2009, 10:15 AM
That was my hassle...... it took a week of a gear puller and PBlaster to shift that outer bearing.
Every day a bit of a turn on the puller, and a shot of PBlaster. Finally it came loose with a bang.
kc5ezc
03-12-2009, 10:42 AM
You might try 50/50 ATF and acetone. Seems to work better than PB blaster for me. YMMV. Acetone evaporates fairly quickly so you have to keep replenishing the mixture.
Brett
03-12-2009, 11:33 PM
I will try the puller , but what is PBlaster Brett
03-12-2009, 11:40 PM
A penetrating oil, like Kroil, the old Liquid wrench, etc.
Brett
03-12-2009, 11:56 PM
I have a pc in the shop so I can do this. It worked and I love it, it popped right out Only Brock one thing getting the hole thing apart so I will weld it up, Brett thanks again
