Dunc
03-17-2009, 11:32 AM
Need to make some replacement shafts that incorporate snap rings - the ones that need the pliers with the little tips.
Shaft is 5/8 inch diameter. I have the original rings.
1. Do I simply measure the id (the rings need to be expanded to remove them) of the ring and its thickness and then grind a lathe bit - thinking parting-tool like - to reflect the width and then "part off" to the depth required by the id of the ring?
2. Should there be some clearance between the inside of the ring and the groove diameter? Is the ring supposed to grip on the shaft by its inside diameter onto the shaft? Or should there be clearance? If yes, amount?
3. Can I re-use the originals or best to replace?
4. Or?
4. Or?
