My bro's going solar @ his electrical shop and Iv been on the panel mount engineering design duty end of it - he had the initial idea of going with uni-strut to his steel building and also using angle aluminum but the rest of the design is how I put the stuff together, first off I attached both angles of the aluminum to the steel strut for optimal support (the top and sides) --- stainless steel washers are used between the two to eliminate galvanic action, all aluminum that has steel fastening hardware has at least stainless washers and sometimes even bolts and nuts depending on the situation,,
second up was coupling the end pieces together --- i lathed up some appropriate spacers and used a 1/2" by 13 bolt/nut and SS washers to clamp it down, these are 2" by 2" angle alum. and I think 1/8" or 3/16" thick ---- i took a pretty heavy guy up in the snorkel lift and he hung off the end of one no problemo --- he was probably at least 225lbs --- I think I could have jumped on too with no probs...
When i tied them all together with the panel rail they really got strong in every direction --- this pic below shows how I staggered every other one of the struts in build design (the angle of the aluminum) -- I built odds and evens and installed one odd to one even - repeat --- what this does is it takes care of the inherent weakness that the bottom and top angle have in one direction --- due to the bottom being a compression and the top the opposite if all units faced the same direction there would be an inherent flaw in side load stability -- this is going to be critical when the panels get loaded up with potentially thousands of pounds of wet snow.
