View Full Version : annealing brass
rgbai
03-25-2009, 04:51 PM
I am going to make some of these brass cases for reloading .32 rimfire using blackpowder
http://www.dixiegunworks.com/advanced_search_result.php?keywords=rimfire+case&x=0&y=0
what will i have to do to anneal (assuming i need to)the cases
JCHannum
03-25-2009, 05:36 PM
That is interesting, the description is a bit misleading. It says to use a 22 short in one place and a 22 short blank in another. Definitely use a blank.
There should be no need to anneal, but if you do, just heat to red heat with a propane torch and allow to cool. You can quench in water or air cool depending on how much of a hurry you are in.
gearedloco
03-25-2009, 06:08 PM
That never stopped me before.
AFAIK, .22 cal. are rim-fire, and the primer is not replaceable. Somehow the idea of heating a case with a live primer in it sounds a tad bit, ummm, questionable.:eek:
Obviously I'm missing something. Please enlighten me. Thanks!
-bill
rgbai
03-25-2009, 06:29 PM
There reusable you put a new .22 blank in the base when you reload them.
SGW
03-26-2009, 08:17 AM
What do you think you need to anneal?
Be sure you get the headspace correct, both for the blank and for the outer case.
