View Full Version : checking my work
bhjones
04-05-2009, 10:14 PM
The old motor in my Sheldon died (bearings) so I picked up a Dayton 3/4hp 230v to replace it. The motor is model 5K460C and the drum switch I'm using is a GE model CR102B. Both components have their respective schematics but I want to run this past people who are in the know and make sure they're compatible. The drum switch is powered by a magnetic switch.
Here are some photos of the docs (sorry, they are big).
http://www.5foot2.com/forum_pics/img_0439.jpg
http://www.5foot2.com/forum_pics/img_0441.jpg
Thanks.
Roy Andrews
04-05-2009, 11:22 PM
yes the "t" leads are all labeled the same and have the same function from the limited view i can see of the print. t1 and 4 are one winding and don't change and T3 and 5 are switched to reverse. if the motor goes in the wrong direction swap 1 and 4 or 3 and 5. to make it right.
bhjones
04-06-2009, 12:27 AM
The switch schematic shows T2 splicing into T3.
I'm assuming I can just run a jumper from the T2 lug to the T3 lug on the switch?
bhjones
04-08-2009, 10:50 PM
I wired this motor and switch up this evening. It works on one direction, but when I try to reverse the rotation it trips the breaker at the panel.
I'll be double checking my wiring tomorrow when I can look at it fresh, but until then does anyone have any ideas?
The switch says "instantly reversible 5 lead motor" on the schematic. And the motor that came out did have 5 leads. Is it that I have the wrong switch for the motor I'm running?
