ptjw7uk
04-21-2009, 07:34 AM
Hi All,
Just looking for some info on the correct fitting of thrust bearings in that in some drwaings of cross slide conversion to thrust bearings a normal bearing is used I assume to keep alignment of the shaft especially if needle thrust bearings are used. So are normall bearings needed if the ball type thrust bearings are used instead of needle type.
Peter
Peter
