View Full Version : Rather unorthodox, but hey, it worked
dockrat
04-24-2009, 10:42 PM
So I had to mill an arc into the base of a ½ inch wide jam cleat I was making for the boom on my boat. The radius of the arc had to be 1 ¼ “ I didn’t have a ball end end mill with that radius but I did have a 2 ½” face mill but couldn’t figure out how to make it work on the mill. I know John S. did something like this on the back of a brass rack if I remember correctly but I couldn’t find the link. After thinking about this for a while I decided to move the job to the lathe. I mounted the part in a tool holder for my QCTP then set the tool holder height for center using my handy dandy laser center finder like this:
http://i253.photobucket.com/albums/hh67/Dockrat1/IMGP1224Medium.jpg
I then mounted the face mill into the chuck. It had to be extended more than I liked in order to cut the length of the part without hitting the chuck but it was just going to be a light cut and only a few thou deep so I snuck up on it gently. Like this:
http://i253.photobucket.com/albums/hh67/Dockrat1/IMGP1227Medium.jpg
All seemed fine so I engaged the feed and away we go:
http://i253.photobucket.com/albums/hh67/Dockrat1/IMGP1228Medium.jpg
And here we are. Worked just fine.
http://i253.photobucket.com/albums/hh67/Dockrat1/IMGP1230Medium.jpg
rockrat
04-24-2009, 11:05 PM
Nice work. That creates a nice shallow curve to the surface.
Thanks for sharing.
rock~
kendall
04-24-2009, 11:07 PM
Sweet!
Now you have me looking at some of the off the shelf things on my boats that I'm not happy with.
For some reason I've made plenty of parts for the bikes, and cars, but projects for the boats have been limited to fiberglass or wood.
What boat do you have?
Ken.
dockrat
04-24-2009, 11:08 PM
Sweet!
Ken.
Catalina 30 Ken
Paul Alciatore
04-24-2009, 11:30 PM
Good job. Good use of your imagination.
04-24-2009, 11:33 PM
Looks good Ernie. I use milling cutters frequently on the lathe for a variety of jobs. They make excellent boring bars in a wide variety of sizes.
RPease
04-24-2009, 11:55 PM
Very nice Dockrat.
If you have to make any more.......and are still concerned about how far the cutter is sticking out, you could reduce the overhang and just cut half of the part.........then move the part over to the other side of the cutter and cut from the back side.
Of course, you'll be cutting on the "upstroke" but that shouldn't be too bad. Especially since you're taking small cuts. The centerline of the cut shouldn't change and you'll still have the same result.
That also allows you to be able to make an even longer cut if you happen to have a longer cleat to modify.
Regards..........Rodg
Spin Doctor
04-25-2009, 11:39 AM
While I am generally not a fan of holding milling cutters in a three jaw chuck in this case it seems to have worked rather well. And it is nice to see somebody else using a BVB-25 type lathe. But I was wondering if you were unable to reach the cutter with a live center in the tail stock?
John Stevenson
04-25-2009, 11:56 AM
This post ?
http://bbs.homeshopmachinist.net/showthread.php?t=20970&highlight=rack
dockrat
04-25-2009, 01:15 PM
This post ?
Thats the one John. Thanks :)
kendall
04-25-2009, 04:12 PM
Catalina 30 Ken
Good boats, one of my old mooring neighbors had one. (his boat was nice, but he was a pain!)
I have two boats, an Ariel and a Triton (26 and 28ft respectively)
been lucky with the metal parts on my boats, every time I need or want something, I've run into someone who's upgrading.
Ken.
