View Full Version : motorcycle stering stem?
dilligaf
04-28-2009, 06:18 PM
I am making a replacement stering stem for a springer front end i am putting on my chopper. What would be the best machineable and strongest materal to use in this application? I talked to Mondo from denver choppers and he said any steel would work since there is not lateral forces but i want decent machineable steel. I tried using i belive A36 just some junk cold rolled with mill scale. How would 1144 or 4140 or something else. I dont want to get into heat treating since i am not set up for that.
thanks
JAson
x39
04-28-2009, 06:48 PM
How about pre-hardened 4142? Will you be welding it or making a mechanical joint? Most stock steering stems are made of tube.
Peter.
04-28-2009, 07:49 PM
Many modern stems are machined from aluminium alloy. My bike and my brothers bike both are. I certainly wouldn't make it from any hardened steel, as above mostly they are mild steel tube.
GKman
04-28-2009, 08:10 PM
If it goes wrong, have the widow post what you decided to use.:D
Rustybolt
04-28-2009, 08:56 PM
What are you making the rest of the frame out of? Make it out of that. Somebody will point it out if I'm wrong ,but I dont think welding a CroMolly to just any old DOM is going to last.
dp
04-28-2009, 10:38 PM
That is one of the most stressed parts on a motorcycle. Springer forks are also the most unstable arrangement ever conceived. There are lots of lateral and twisting forces on the steering head parts and they're not trivial. It is my opinion that the steering components can not possibly be over-engineered. There's a reason H-D recommends inspecting the bearings at 10K intervals.
But I have to admit springers are the coolest looking forks for a chopper.
oldtractors
04-28-2009, 10:48 PM
How much engineering and thought do you think went into the aftermarket front ends that you can buy out of a catalog. Those things and aftermarket wheels made by some yahoo with a CNC mill scare me to death.
jason
04-28-2009, 10:54 PM
The spring was the most widley used front end in history and are no more dangerous than moderan forks. Mondo the grandfather of the long bike (motorcycle with the very long front ends) and the nomber 1 springer builder says there is no lateral pressure on the stering stem even if the front end is 3" or 11" over stock. The stem will be one piece of solid ?? and screw into the bottom tree of the springer. This is the way the springer is now but it is for a different bike than mine so the berring races are different so instead of cutting the neck off i am replaceing a removable neck stem.
thanks
Jason
dp
04-28-2009, 11:19 PM
Evasive maneuvers put a lot of lateral and twisting stress on the steering head. I've chirped my front tire avoiding road hazards. It's even worse with stretched and raked front-ends with overbite (contact patch is ahead of the axle) that cause the bike to fall face down low-side.
Check out the maintenance recommendations and costs for a stock Harley springer.
pressurerelief
04-28-2009, 11:27 PM
Ask "Mondo" where he got his engineering degree from, Is he a P.E., and what type of stress analysis was undertaken. I can guarantee you there are stresses in that system that must be qualified and quantified or the result will be less than desirable. Anybody can put something together for a show bike, but for a daily rider out on the ride the rules are a little different. Personally I would not ride one of those OCC "Bikes" to my neighbors house.
P/R
jason
04-28-2009, 11:37 PM
I have worked one on one with engineers and most dont know anything about what they are drawing. I would rather trust somone that have been building and using the product for more than 30 years. I have seen many times where something was designed to where there is no way to build the thing.
barts
04-29-2009, 12:17 AM
thanks
JAson
Stressproof (1144)would work well for this.
Guys, before we get all bent out of shape on the stress analysis
Draw the force vector on heavy decel - it's almost right up the fork tubes.... which means that the bearings take the guff, not the steering stem.
On steering transients, we get some side load - but again, the triple clamp & forks force this right into the bearings. The handle bars fasten to the top triple clamp - so the force is carried by the fork tubes.
The head set tube should be really strong, along w/ the frame that ties into it - but the piece connecting the two triple clamps isn't that loaded. Make it out of some strong tube (or solid if you must), and you'll be fine.
Engineer in some tapered roller bearings w/ good grease seals while you're there - that will keep the bike handling better for a long time.
Doozer
04-29-2009, 01:02 AM
I used stressproof 1144 for my steering pivot shaft. It is 13" long and it started at 1.375 dia. The nuts on the top and bottom are 1"-16 thread.
Used tapered rollers and labyrinth seals. Should survive hitting a tree.
http://i72.photobucket.com/albums/i169/kooldoozer/IMG_0279.jpg?t=1240977540
--Doozer
chief
04-29-2009, 07:47 AM
I use grade 5 titanium but these are for race bikes and the stems are periodically inspected for cracks and wear.
dilligaf
04-29-2009, 09:50 AM
thanks for all the replys 1144 it will be.
Jason
plastikosmd
04-29-2009, 12:28 PM
doozer, more pics please..esp if that is a trike/atc
RobbieKnobbie
04-29-2009, 02:14 PM
Say what??
madman
04-29-2009, 04:58 PM
From 4140 or 4340 material, either one would work, Keep in mind in the olden days a guy with common sense would make something solid and heavy and it worked. NOW adays with the advent of computers and internet and everyones a expert on everything BUT they have never done much of ANYTHING so to speak, If you just made it from decent material like 4140 A (annealed0 it would do the job Fine. No worries. good Luck, PS you should see the cheesy front end on my 150 mph plus bike (I think its a part of a old honda 750 and other homemade junk, hasnt snapped of yet??? Been there over 20 years plus.
steverice
04-29-2009, 06:06 PM
We go 200+ with aluminum stems, don't think I would do a chopper with one though.
Steel, 4130 or so.
s.r.
mark61
04-29-2009, 08:46 PM
Accurate discription of majority of replys to this and many posts on this and many web sites anymore!
mark61
KenL
04-29-2009, 09:04 PM
Gee, where have I heard that line before? Makes me wonder why we engineers spent all that money and time earning degrees when we could have simply asked a builder who holds all of the knowledge of mankind. Darn, I hate it when the simple stuff goes un-noticed for so long.
I personally received quite a detailed summary of how we should design helicopters from a chap at the lumber counter one day. Since he couldn't add up my change correctly, one wonders how he would have handled rotorcraft stability derivatives!!
My Dad was a mechanic and welder, very good at both, but was in no way qualified to design anything for public consumption. Bottom line: be careful about hanging your neck on a motorcycle built by anecdote; it could prove a rather interesting ride!
kendall
04-29-2009, 09:09 PM
I used to get pretty crazy on bikes, canyon runs, twisties, or just flat out speed runs and have really stressed them. The first time I tore the stem down I was dumbfounded that I was trusting my life to that 'wimpy' stem.
Most I have torn down have been mild steel tubes, welded in the tree on one end and threaded on the other.
The only ones I've run into that weren't tubular were on choppers, either on springers or girders, extended stock forks were tubular.
Ken.
Doozer
04-29-2009, 10:25 PM
http://s72.photobucket.com/albums/i169/kooldoozer/
--Doozer
