rockrat
05-11-2009, 07:55 AM
I needed a round piece of stock bent with low precision the other day and I have never put together a wire bender for the shop. I really didn't have the time to make what I have wanted (Diacro clone) but I quickly found a solution.
I have a junk vise that I have on the welding table for beating on and such. I poked a hole in the fixed jaw for a retaining rod. I went over to the toolbox and found a socket that was the correct diameter for what I needed. I was planning to just clamp the socket in the vise and after heating the wire, make my loop. But I noticed that I had these little adapters for my sockets.
http://s.sears.com/is/image/Sears/00943303000-1?hei=180&wid=180&op_sharpen=1&qlt=75
I clamped one of these up in the vise with the socket on it, heated up the rod (hey, the torch was right there, why not) and made a nice little bend. The adapter kept the socket from flailing around as pressure was added. I need to try this cold and see what results I get.
Click for larger photo-
http://img.photobucket.com/albums/v12/rockrat/projects/wire%20bender/th_IMG_7638.jpg (http://img.photobucket.com/albums/v12/rockrat/projects/wire%20bender/IMG_7638.jpg)
http://img.photobucket.com/albums/v12/rockrat/projects/wire%20bender/th_IMG_7639.jpg (http://img.photobucket.com/albums/v12/rockrat/projects/wire%20bender/IMG_7639.jpg)
I played around with this and found that I could move where the socket was clamped up and allow for different rod diameters and socket diameters. I have some old broken socket extensions that I now have plans for, if I can find them. I plan to use an extension to replace the socket adapter. If I cut flats on the sides and weld a flat on the bottom of the extension I can keep it from rotating in the vise. But that wont happen until I need it again. Who knows, maybe by then I'll have time to make a nice stock bender.
rock~
rock~
