View Full Version : Outside cherry picker, trailer concept drawing
Dawai
05-11-2009, 09:31 AM
http://img.photobucket.com/albums/v85/ibewgypsie/Outsidecherrypickertrailer.jpg
Able to pick up car engines, carry them down the road, lay in floor spars.. JOHN S suggested this. I am scrounging parts to build. Able to tote anything the HSM needs with mods.. I am trying to figure how to make a car dolly from it also.
rockrat
05-11-2009, 09:54 AM
Add a bar cross the top of the triangle for the axle from one side to the other and you could be haulin B'ports around. Back up, lift the machine, add the spar in the correct place, lower machine onto spars and drive.
Your a millionaire if you dont tell anyone till your ready to sell! Oooops, too late. :)
rock~
digger_doug
05-11-2009, 10:00 AM
Sorta like this:
http://www.fisklptank.com/ezt/index.asp
rockrat
05-11-2009, 10:13 AM
Almost looks similar to a casket/vault trailer. I wonder if I can get one of them from Craigs list? Hummmm...
rock~
digger_doug
05-11-2009, 12:10 PM
And this, note how it cantilevers off the back and swivels
side to side (somewhat)
http://www.gizmoplans.com/build_your_own_3000_lb_dot_truck_loader.php
OOOHH, OOOH, use dodge caravan rear axle stubs.....cut off the axle.....
weld to a heavy box tube (2" x 4" x 1/4" wall) and make it a double with a walking beam.
I'm salavating already.
