tiptop
05-11-2009, 09:26 PM
Hi All,
Well, I had one last thing to finish on the Monarch before getting going to strong on the S.B. The pull knob on the shifting arm of the change gear box for threading was broken and the previous owner had tried to repair it with epoxy. I took it apart and built a new stud for it with threads, drilled and threaded the hole in the arm and installed the new part. It seems to be working fine now. Nothing like a machine making it's own repair parts. Threading on that Monarch is a breeze. It was a fun little job. Here are some pictures.
This shows just the rod in place for cutting the threads on the new knob.
http://photos.imageevent.com/aatiptop/toolspage/monarhlathe/websize/Monarch%20Lathe%20010.jpg
This is the taper pin, spring for loading, the broken knob and the pull handle.
http://photos.imageevent.com/aatiptop/toolspage/monarhlathe/websize/Monarch%20Lathe%20011.jpg
This is the parts put back together with the new threaded knob.
http://photos.imageevent.com/aatiptop/toolspage/monarhlathe/websize/Monarch%20Lathe%20012.jpg
This is it being installed back on the shifting arm.
http://photos.imageevent.com/aatiptop/toolspage/monarhlathe/websize/Monarch%20Lathe%20013.jpg
Cheers, Jay
Cheers, Jay
