View Full Version : Surface grinder coolant flow
lakeside53
05-20-2009, 12:33 AM
I'm restoring a 1957 Brown and Sharpe 2L 6x18 automatic surface grinder. I'm right at the point of finalizing the electrics and want to make provision for a coolant pump, but have no idea what size I'll need.
What type of flow is required? Dribble, flood, gusher?
Also.. what type of coolant is used?
websterz
05-20-2009, 01:20 AM
Nothing like bringing old iron back to life! I just finished my 1951 #25 Gallmeyer & Livingston grinder. She's a good looking gal, a hard worker too. She doesn't look a day over 35! hehehe :D
As far as coolant, I use a small 12 volt DC bilge pump I bought in the sporting goods dept. at WalMart. I run it off of a 12 volt battery charger, drawing coolant from a 5 gallon bucket. I put a sock on the return line to filter the fines, and a speaker magnet in a ziploc bag in the bottom to collect what gets past the filter. Any soluable oil will work for coolant. I use some cheap stuff I get from Enco, about $16 a gallon for the concentrate. 1 gallon makes about 40 gallons of coolant when mixed. At that price I use it a month and then change it out. A local machine shop lets me dump it into their non-haz mat barrels for disposal with their own fluids.
