Steve Rundell
05-28-2001, 08:00 PM
Help!!!
It finally happened; I bought my first metalworking tools, in this case a Craftsman lathe and drill press. They are both from the estate of a friend of mine, and I would guess them to be around 1950-1960 vintage, althought I don't know for sure. The lathe measures about 12" x 36". Its label plate says '101-07403'. The drill press is a table-top model, but it's huge! It was made by King-Seeley, and is labeled '103-23130'. There is also a monstrously heavy rotary table with X- and Y-axis movement, and a whole bunch of tooling.
I'll be building tables for each of these goodies, but I need to clean them up first. What should I use? Should I buy an automotive-type solvent tray? After I get them cleaned, what should I use to prevent further problems?
Any advice will be greatly appreciated.
I need advice along two lines;
1. Where to get owner/operators manuals for these machines, and...
2. How to clean them up. There is a little surface rust, but mostly they are just dirty (very), with grease and a nice coat of dust and sawdust.
