View Full Version : Air Rifle Question
mrhemi
06-13-2009, 07:55 AM
I have an older Slavia 630 break barrel air rifle in .177 caliber. For the Canadian market this gun was derated to less 500fps muzzle velocity. What I would like to know is if the muzzle velocity can be increased by sourcing a higher rate spring (if so where?) or machining a spring shim to increase the preload. Also, much the same question for a Beeman air rifle. If I have a Canadian market version with the lower muzzle velocity is there a means to increase it?
Mr. Mike.
huntinguy
06-16-2009, 05:26 AM
There are a few blogs around for airguns, even a few Canadian ones.
From what I understand... some of the airguns are derated by drilling holes in the pressure tube and others by reducing the strength of the spring.
I don't have my list of links here but there is a forum... Airgun Machinist Workshop... I think. You might ask over there.
deltaenterprizes
06-16-2009, 09:22 PM
Please try to find the link,Google search did not turn up any results.
knedvecki
06-16-2009, 10:08 PM
Lookee Here : http://74.125.93.132/search?q=cache:jjimELdxg5oJ:ccairguns.aimoo.com/DIY-1-3320+Airgun+Workshop&cd=4&hl=en&ct=clnk&gl=us&client=firefox-a
chuckinnc
06-17-2009, 08:08 AM
Google Chinese airgun forum, I was active in this forum years ago when hi
power Chinese airguns hit the market. It was common practice to replace the
stock spring with a Maccari spring, you can also find info on better seals.
There are alot of tips on how to increase FPS for any brand of airgun.
huntinguy
06-18-2009, 07:03 AM
http://www.network54.com/Forum/79537/
http://www.network54.com/Index/82760
moe1942
06-18-2009, 09:01 AM
Lot of good people and info at airgunone.com
Yankee1
06-20-2009, 09:35 PM
Hi
When the piston comes to a stop the air has been compressed into a given space. If that space is reduced the pressure will go up and the velocity increased. Redesign the piston to accomplish this. A longer barrel will increase the performance also. With a precharged pneumatic the space after the regulator is increased to accomplish an increase in velocity.
With the pneumatic using a longer barrel will tend to make it much quieter.
Yankee1
NickH
07-25-2009, 04:06 AM
Try
http://www.airgunforum.net
and
http://www.airgunbbs.com
The forums there are a great source of information.
Stronger spring, increased swept volume and reduced (if any) headspace will all increase power.
If the trigger mechanism latches on a rod which extends from the piston head out the back of the spring then this is often lengthened to reduce power, if you have spare length & the spring & cocking mechanism will deal with it, shortening this is one way to increase swept volume.
Barrel length is a funny one on a springer, on high end guns like the Beeman R1 shortening the barrel can increase power, on PCP & CO2 lengthening gives more up to a point,
Regards,
Nick
