View Full Version : What size rotary table?
Boucher
06-24-2009, 10:29 PM
When I bought my first Bridgeport it came with a ten inch Enco rotary table with a 12 X 18 X 1.5 inch Well used Al tooling plate attached. It is heavy and consequently it has not been used a lot. I had never seen and therefore never thought much about a smaller rotary table. I saw one recently that was about 6 inch. that looked like it would be very easy to use. A quick look in the Enco catalog shows a Phase two for a couple hundred Dollars. What size brand and quality are you using and what would your reccomendations be?
Rich Carlstedt
06-24-2009, 10:52 PM
There is no perfect size.
On my bridgeport, I use a 6 inch atlas, a 8 inch palmgren and a 12 inch NEWS ( Yuasa)
I use the smallest one that works, for the level of accuracy I want
I would say a 8 inch should work for most
Rich
JoeFin
06-24-2009, 11:11 PM
Depends on your back - or if you have a small jib-crane next to your mill
I had a 18" Troyke that would exceed the table load on a lot of mills. Then a 6" phase II and now I'm happy with my 12" Yusa (but I have to think about it before picking it up)
rode2rouen
06-24-2009, 11:23 PM
To eliminate the grunting and groaning when switching from my vise to my 9" Troyke rotary table, or vise versa, I have a roll around cabinet for mill tooling that has a 1/4" plate steel top. When it's time to switch, crank the table to cabinet height and slide. It also solves the "Where do I keep this when it's not on the mill?"
I'm too old to have another hernia operation!
Rex
http://i721.photobucket.com/albums/ww216/bjorn_toulouse/Vise%20Swap/vise4.jpg
http://i721.photobucket.com/albums/ww216/bjorn_toulouse/Vise%20Swap/vise5.jpg
