View Full Version : Stepper Motor Temperature?
japcas
06-28-2009, 08:16 PM
Hey guys. I'm working on a small cnc xy table to mount up on my mill. This is my first cnc build although I run manual and cnc machines for a living. I wanted to start out small with a 2 axis system and if everything works out o.k. maybe later on build a full 3 axix machine with a 4th axis indexer.
Now to my question. How hot should the steppers get when just sitting idle configuring Mach3. I have all of the wiring done and going through the manaul configuring the system. I can hold them for about 6 seconds before needing to put them down. I checked them with an infrared thermometer and it measures about 120 degrees. They move around fine and everything seems to be wired correctly. Is this normal?
rotate
06-29-2009, 11:26 AM
120 degrees what?
Motors should typically rise 40-60 degrees Celsius, but no more.
japcas
06-29-2009, 12:15 PM
Sorry. 120 degrees F. I lowered the Vref on the stepper drivers and they are running about 90 degrees f now. Which is about 34 degrees c. I think they are fine now.
macona
06-30-2009, 02:41 AM
Some nicer stepper drives will lower the current on idle to avoid heating.
Figure the insulation is probably rated for 90 degrees C.
Davidhcnc
07-05-2009, 12:40 PM
If you can get the data for your steppers it will state the operation temp range and the allowable temp rise.
so mine are
0-50 deg C operating( ambient)
70 deg C allowable temp rise.
This is a typical rating for steppers so I'd say yours are normal.:)
