View Full Version : Dumore pulley size(s)
07-10-2009, 09:07 PM
Any Dumore grinder (44 series I think) owners out there who could provide the
pulley wheel diameters. I have a #4 (2 1/4") and a #3 (1.556). According to what is legible on the chart on the motor I think I need a #2 to reduce the rpms to around 6000.
07-10-2009, 10:37 PM
To get 6600RPM at the spindle, you need #2 (1 1/8") on the motor, and #4 (2 1/8) on the spindle.
PM sent, if you want the page from the Dumore catalog.
Dave J.
07-11-2009, 01:03 AM
Here's the label on mine. Having the full set of five comes in handy. Especially to do small ID grinding. I think I made three for mine. Pretty simple to make if you have a radius/ball cutter for your lathe. I'll have to look but I may have some 3/4" aluminum plate stock left. I just used a hole saw to blank out the sizes I needed and cut them on the lathe.
07-11-2009, 02:07 PM
Dave and Ken Thanks for the info. I updated my email address. After cetlink was bought by navacore I updated about a thousand of them, should have done 1001.
07-12-2009, 06:12 PM
Looks like you have the info, but its not in the posts, so in case anyone else needs it, mine measure as follows, at largest part of crown. (inches)
1 .85
2 1.125
3 1.56
4 2.125
5 3
