View Full Version : Gearcutting 101...
Davek0974
07-11-2009, 07:10 AM
Hi all,
i need to cut some large gears in cast iron, max dia is 495.30mm with 76 teeth in 4DP, the rings are all about 25mm thick.
Rather than send them out, i want to do them myself. I have now equipeed the shop with an Adcock & Shipley 2E horizontal mill onto which i can mount my 12" rotary table. I have some cutters coming in the correct ranges for each teeth set.
I know about bracing the wheel under the cut and centering the cutter on the table axis, also keeping the arbor support as close as possible to the action, obviously the cut will be made by lifting the knee.
What i need to know is, how do i work out how many passes to take for each tooth and what speed to use - is it the same as ordinary milling?
I'll also have to make or find some dividing plates to fit this table, it currently only has a direct degree scale plus a vernier scale reading to minutes and seconds.
Any help is much appreciated as always.
aboard_epsilon
07-11-2009, 08:46 AM
I'm no gear cutting expert ..
but just thinking about the 76 teeth and winding the knee up and down ,..probably four times 76
makes me break out in a sweat http://media.bigoo.ws/content/gif/smiles/smiles_62.gif
spinach anmd popeye come to mind .
all the best.markj
Timleech
07-11-2009, 09:23 AM
Hi all,
When doing that big flywheel ring gear I did it with one pass per tooth, not a problem at 8DP. I'd guess that at 4dp you would be better with at least two passes, maybe making the first with a slot cutter. I did make a first run round taking off a few thou just to check the division setup was OK (I was using a stepper driven rotary table). Unless you have power feed to the knee, you'll have some good muscles in your arm by the time you finish!
Tim
The Fixer
07-11-2009, 09:55 AM
I agree with the guys about the setup...... If u really have to use the rotary table build yourself an agle plate and mount the RT at 90 deg so u can use the table feed. I did a few 56 t gears recently and it was a long process even with the power feed!
Is this a metric gear or imperial? if it's metric u need a mod gear cutter not a DP although if it's a slow run gear with adjustable clearance it will likely work fine. The formula for depth of cut escapes at the moment but when I bought my cutters it had the wd right on them.
BTW what # cutter did you order I'm guessing a DP 4 #7?
al
andy_b
07-11-2009, 09:58 AM
i never cut gear teeth before and i'm not understanding something in this setup. don't you just set the knee so the cutter makes the correct depth of cut and then run the table horizontally into the cutter for each tooth? i'm talking for a horizontal mill here. why would you need to raise the knee into the cut, and several times at that?
andy b.
The Fixer
07-11-2009, 10:05 AM
Andy, he wants to use a rotary table not an indexing/dividing head....
al
Davek0974
07-12-2009, 11:12 AM
Thanks all so far,
Its a 4DP job, but i work in metric so the diameter is 495.30mm or 19.5". This ring with it's 76 teeth will require a No.2 cutter. The whole job will require No's 2, 3, 4 & 7 with teeth counts ranging from 15 to 76.
Yes, i'm using a rotary table, i cant see any setup being more stable than a rotary table laying flat on the bed with a 19.5" ring on top, i would never want to attempt a peripheral cut on that ring with it standing up.
BUT, now that you've mentioned it, i can see the merit of gashing the ring with a plain side / face cutter smaller than the tooth root and almost to depth first. This cut can be done using the table traverse, feeding into the cutter on center.
The final cuts must be made by the knee or i will end up with concave teeth.
So, presuming i have removed a fair chunk of iron from each tooth, would the shaping cut be possible in one pass?
Thanks
Timleech
07-12-2009, 11:29 AM
Thanks all so far,
Thanks
If your wheel overhangs the edge of the rt, try to arrange a packing block between wheel and mill table. I used a block af Ali, with a shim to complete the gap which I slid in before each cut and out before turning the RT.
I don't see why you shouldn't finish in one pass if the centre has been removed first, you'll have to suck it & see with the feed rate for a decent result without too much stress & strain.
Tim
Davek0974
07-12-2009, 12:06 PM
Yes, i'll definately give it some under-support near the cut.
I think the cutters are about 4-1/2" dia so i'm guessing about 100rpm?
andy_b
07-13-2009, 01:43 PM
can't most rotary tables be mounted vertically? wouldn't the force of cutting on the gear be the same moving the knee up and down as moving the mill table left and right? like i said, i never cut gears and i'm no machining expert.
if it was me, i'd somehow find a way to mount the gear vertically, but i'm stubborn (and sometimes lacking in common sense). :)
andy b.
aboard_epsilon
07-13-2009, 02:34 PM
andy b.
its the force required to lift the knee without cutting ..this is hard work in itself
you try it ..wind your knee up and down ..probably 5 inches or so that is required to take it in and out of the cut, then think about doing this 74 times ..that's just for the first cut, then you got the same for each and every tooth.
it will require perhaps one or two more passes after that .......so you could be winding it up 222 times ..and winding it down 222 times.
so you'd be lathered sweaty.......all this whilst trying to work out the sequence of dividing.
time to buy Tony's division master i think ..
all the best.markj
Davek0974
07-13-2009, 03:45 PM
Vertical mounting is the weakest method of using a rotary, the problem will be worsened when you take a 12" table, stand it up and mount a 19-1/2" wheel on it:eek:
Cutting with the table horizontal sends all the forces straight into the knee.
The time taken is irrelevant, it won't matter if i only manage two or three teeth per evening, what matters is being able to say "I cut the gears" at the end.
John Stevenson
07-13-2009, 05:15 PM
Dave,
Instead of pre-gashing the teeth and wearing your arms out, what about pre-drilling on the Bridgy before transferring to the horizontal ?
http://www.stevenson-engineers.co.uk/files/76T_4DP.jpg
Two holes, 6mm and 10mm will remove most of the meat for a final pass with the gear cutter.
andy_b
07-14-2009, 11:39 AM
i missed that key part. :) yeah, i guess by the time you come up with a stack of metal to bolt the table and 20" gear to, that might be a bit unsteady. at least the gears aren't 4" thick so you don't have to move the knee up and down 6" per cut.
andy b.
Davek0974
07-14-2009, 03:48 PM
Thanks John, Andy, all,
i guess any method of pre-removal of waste is a good thing but i hadnt thought of drilling.
I'll choose which method when i get the mill cleaned up and installed, found most of the cutters i need, just one to get now.
Having finally realeased the last owners cutter from the long arbor, i find the key missing:( I guess it is just standard key material 1/4" x 1/4" in this case but should it be as long as the shaft or just a short bit?
The missing key explains why i had to use a 30" breaker bar on the arbor nut:mad:
John Stevenson
07-14-2009, 03:57 PM
The key only needs to be long enough to go into the spacers either side of the cutter and the cutter itself.
One note when using slitting saws on a mill, NEVER fit the key.
The reason is that if it grabs it will try to spin, the key will prevent it but because they are so thin the key will then explode the saw.
Always best to tighten it and allow movement if it grabs or jams.
Often on older well used horizontals you see grooves in the keys where one has spun and it's took a piece out of the key, in those cases someone was lucky, when they are unlucky you get razor sharp shards of HSS cutter wallering round the shop.
Davek0974
07-14-2009, 04:17 PM
Thanks John
i know about keys in slitting saws from the bridgeport, always left out.
The cutter that was left in the mill was 1" thick by about 6", stagger-tooth, side & face. That arbor nut was **tight**. I suppose leaving the key out saved about 15 seconds of time :rolleyes:
lazlo
07-14-2009, 05:03 PM
Cool idea John. :)
andy_b
07-14-2009, 08:16 PM
how did you get the arbor nut off? i have an arbor with about a 10" x 1/8" slitting saw on it. well, more like a metal-cutting table saw blade. :) the nut is on there so tight i have yet to find a method to loosen it. i have had this arbor for about four years and every now and then give a try at getting the nut off. i was thinking of putting it in the lathe and cutting the end of one of the spacers down with a cutoff tool.
andy b.
lane
07-14-2009, 09:14 PM
Since know one has said it I will . All is good and doable.But i would be looking at a way to rig up to power drive the knee. A motor clamped to the table running threw a gear box and a chain drive fixed to the knee crank. I rigger up something like that once on a old mill just for the reason of the same thing you are doing. Sure beat the heck out of cranking up and down. May be buy a cheap Chinese servo unit and making it work.
Davek0974
07-15-2009, 04:33 PM
andy b.
I soaked it in WD40 for a few days, luckily the arbor-support bearing was near the cutter so i had plenty of spacers to grip. I took it to the engineers next door to my work place, stuffed it in the biggest bench vise i had ever seen, gripping on a spacer sleeve near the nut, stuck a wrench on it with a tube over the handle then with my foot on the bench a couple of good hard tugs had it loose.
The next option was to apply a little gentle heat.
