gfphoto
07-11-2009, 03:09 PM
Here are some modifications to an HF magnetic base (http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=5645) I got a few weeks ago.
For ten bucks it's a pretty amazing value. However...
One of the plastic knob/nuts broke off so I suspended the remaining piece with the sleeve with the metric? threads in epoxy and after it hardened turned it to make a nice round knob - one that can be easily turned from any direction in sometimes limited space, and easier to grab with oily fingers.
Earlier I replaced the bolt and small piece of knurled rod that held the indicator with a scrap yard quick release, I think from a scooter - much easier to tighten now and stays put. The original would loosen and the indicator would drop just as I was getting the rest in place and tightened.
Also replaced the stock arm (with fine adjust) with a plain longer aluminum rod and added a 4-40 screw at the end so the rod won't fall out when everything's loose. The fine adjust worked okay but didn't seem to be really necessary.
http://www.gfphoto.com/tool/Lathe/HF-dial-indicator-base-mods-s.jpg
The magnet is pretty strong and can hold the rig firmly on a curved vertical surface.
I hope this is useful - I'd like to give back something as I learn here everyday.
Gary
Gary
