View Full Version : Help in Los Angeles
knotty
07-14-2009, 12:45 PM
Hi there, I'm building a small machine that needs a worm drive and gears (metal), the lenght of gear needed is approx 18" and about the size of a dime is there anywhere I can go in the Los Angeles area to find these gears, I'm also looking for some help! As not a pro myselft, maybe a retired gent (Glendale Area) many thanks.
Falcon67
07-14-2009, 01:00 PM
You might check with Stock Drive Products: http://www.sdp-si.com/
Guido
07-14-2009, 02:10 PM
Pack yourself a lunch and go spend the day.
G
Guido
07-14-2009, 02:19 PM
No better than Apex, but right around the corner from Glendale.
G
knotty
07-14-2009, 04:26 PM
Thanks for reply been to both stores no luck at either!
Carld
07-14-2009, 05:38 PM
Do you mean the worm will be 18" long and the diameter of a dime? If so, what is the size of the driven gear?
Rookie machinist
07-14-2009, 07:07 PM
Have you tried bearings & drives in El Monte, pretty good staff there.
lane
07-14-2009, 07:08 PM
I do not know any thing about Los Angeles.But a place that big would have any thing you could want. Get out the yellow pages and look under Bearing suppliers . And Industrial suppliers for power and transmission equipment. such as Motion Industries ,Applied Technology and such. I live in a small town but we have both bearing supply houses plus a local one that has any thing you could ever want in that line of product. L.A probably has a hundred are more of such places.
knotty
07-14-2009, 08:42 PM
The worm drive is approx 18" and the diameter is a nickle not a dime and any gear that will fit! I need the gears to revolve 3 rpm approx and I'll fit a reduced gear motor (150 rpm approx) directly to the worm.
gregl
07-15-2009, 10:31 PM
There's also C&H Sales in Duarte (they moved from Pasadena). Pricey but lots of stuff.
mwechtal
07-16-2009, 01:56 PM
Could you use 2 shorter worms mounted on a shaft? It would likely be much cheaper, easier to find, and you'll likely have to use a shaft anyway.
