View Full Version : Source for B&S Carburetor Parts?
JCHannum
07-18-2009, 06:36 PM
Does anyone have a source for vintage Briggs & Stratton carburetor parts? The engine on my L&S garden tractor is a 1950 B&S Model N, 2HP. The float valve does not seat. Float & all are good. The engine runs well, but leaks through and smokes like a mosquito fogger.
crancshafter
07-18-2009, 06:43 PM
Hi.
Do a google- search on B&S carb-parts an you will find it. Or go to the B&S homepage and you will find what you need. Hopefully.:)
CS
JCHannum
07-18-2009, 06:47 PM
Been there done that. I can find plenty of parts for contemporary engines, not 1950 models though.
lugnut
07-18-2009, 06:56 PM
Jim the fellow that owns and runs/owns the Home Model Engine Machinists forum is a antique B&S restorer I would think he could point you to the parts you need. His name is Rick. His handle on the forum is rake60 http://www.homemodelenginemachinist.com/
Mel
lynnl
07-18-2009, 09:01 PM
JCH, what is an L&S garden tractor? Is that something along the lines of the old David Bradleys or Gravelys? I don't remember ever seeing or hearing of those.
Just curious and didn't find it on google.
Pherdie
07-18-2009, 09:34 PM
I believe this will answer your question:
http://bbs.homeshopmachinist.net/showthread.php?t=35439
Willy
07-18-2009, 10:33 PM
Jim I just had a quick look and don't have time right now for a thorough search (because my wife has her arms crossed and wants to go out for super).
Anyway have a look at these two pages.
The first one has date codes for your B&S model N, a little better than half way down the page, and the second one has carb overhaul kits also a little better than half way down.
http://www.asecc.com/data/briggs/data2.html#N
http://www.manddsmallengine.com/briggs/parts/
Gotta go or I'll be in trouble!
x39
07-18-2009, 11:20 PM
I've had good luck with these folks:
http://www.briggs.learnsmallenginerepair.com/index.htm
rockrat
07-18-2009, 11:38 PM
The local guy that I use has shelves of parts for old stuff but its a crap shoot depending on what is needed. If you have some numbers I'd be more than happy to run over to his place and see what I can come up with.
rock
PTSideshow
07-19-2009, 06:59 AM
http://www.smokstak.com/forum/forumdisplay.php?f=28
And there is a for sale forum to.
http://www.ytmag.com/
You might find some info here on the tractor.
http://www.perr.com/ might have some, they all so have a good info base with the new and old forums.
http://www.mowergraveyard.com/engine-parts-c-82.html?zenid=d1fde27967a85b7148b618f259e8ce5f
New and used engine parts
http://www.jackssmallengines.com/index.html
Good DIY section and assorted other stuff
:D
barts
07-19-2009, 11:40 AM
With simple parts (one piece seat and needle) you may be able to repair these on the lathe. The seat is prob. brass, and the needle is either brass or stainless. If the scoring isn't too bad, simply lapping them together will likely produce a workable pair; with more significant damage you may need to make a tool to form a better seat. The needle is easy to clean up on the lathe once you manage to hold it. A Sherline would be nice for this job...
Floats are harder to repair....
- Bart
JCHannum
07-19-2009, 07:05 PM
Thanks for the suggestions. I have pretty much already checked out most of them to no avail. I will try to contatc Rick at HMEM.
I had to make a main jet for it already and was hoping not to need to do the same for the float valve & seat. It still might be necessary as it is questionable if I can get the seat out.
