View Full Version : Jet gear oil for HVBS-56M
07-20-2009, 05:05 PM
I drained the gear oil on my Jet bandsaw.
The manual says to use Mobil SHC-634.
What is it comparable to?
I thought I was going to use some 90 weight gear oil, but now I'm not sure what to buy, or where to find it.
Ohio Mike
07-20-2009, 09:38 PM
Mobil's SHC-634 is a ISO Viscosity Grade 460 industrial gear lube. A close substitute would be something like Texaco/Cheveron Pinnacle 460, or Royal Purple Synergy 460 but I don't think that's what you're asking. ISO grade 460 that translates to a SAE 140 weight gear oil. If you want the real thing Enco carries SHC-634 in quarts for about $15.
07-20-2009, 10:36 PM
The Mobil SHC 600 series is a heavy synthetic gear oil. SHC-634 is ISO 460 weight, which is equivalent to SAE 140 (i.e., quite a bit thicker than 90W gear oil).
MSC carries SHC-634. It's about $20/quart, but you use very little of it in a bandsaw and it really quieted my Wilton's worm gearbox.
07-21-2009, 12:31 AM
Grainger's has it also. I use it in my lathe QC Gear box.
www.grainger.com Product 4ZF30 - $18.00 a quart. Less if you get discount via a Grainer account.
