View Full Version : J6 Taper
07-23-2009, 09:29 AM
I picked up a Rohm keyless chuck that has a sraight 5/8" diameter shaft. I want to replace that shaft with an MT2 taper. The chuck has a J6 taper. How do I get the old shaft out? And before someone suggests a punch through the jaws,there is no clear passage. Duffy
07-23-2009, 09:45 AM
Mis-entered reply.....
07-23-2009, 09:46 AM
You should be able to drill through the bottom of the chuck to make a hole for a punch.
The "correct" way to do it though, is with chuck removal wedges. (I'm assuming a Rohm chuck will be the same as a Jacobs chuck in that regard.)
