View Full Version : Hendey lathe question
steamwhistle
07-24-2009, 02:46 PM
Hi,
Can anyone give me the weight of a 12 x 30 Hendey lathe built in 1945?
thanks
Hal
07-24-2009, 03:07 PM
If you get no reply check on the PM forum under the antique section.
Hal
drof34
07-24-2009, 04:02 PM
I have a 14X30 Hendey(early 50s: 18 speed), but I don't know exactly how much it weighs. I would guess somewhere between 4K & 5K lbs.
Jim W.
Sorry, I didn't read carefully enough.
Robin R
07-24-2009, 09:01 PM
If you go to this thread on PM, there is a link to a scan of a 1940 Hendey operators manual. It covers both cone head and gear head, I don't know if it gives the weights. http://www.practicalmachinist.com/vb/showthread.php?t=181996&highlight=hendey+weight
Charles Lessig
07-25-2009, 08:01 AM
Hi,
thanks
A 12 x 30 gearhead weighs about 3600 pounds. The bed is about
800 pounds and the headstock about 550.
I had to take mine apart since my celler has a wood stair along a wall.
The bed and headstock came in a small window at ground level. The
headstock needed a special skid because it has a gear sticking out
the bottom. It was a one man job for me in 1986. Not now.
I will leave a set of instructions for my executors when that time
comes. Charlie
steamwhistle
07-26-2009, 12:05 PM
Thanks, Charles.
Now I know what trailer to rent to go get the lathe.
Tim
