M.Baunach
02-07-2002, 06:29 PM
Could use some advise on methods and techniques of cutting fiberglass.
I will need to rough cut 6mm cubes (saw) from rectangular pieces 25mm X 12mm X 6mm.
I will then need to true these rough pieces up using a conventional mill.
What type of cutter, speeds/feed and should I keep cool with airstream?
I'm essentially making small cubes out of larger stock. I can't alter the properties because they will be ultrasonic test specimens for a project. I also do not know the exact composition of these fiberglass specimens.
thanks
thanks
