View Full Version : Aluminum welding
Frank Downey
08-30-2009, 06:31 PM
I have a couple of semi-truck wheel hubs that are aluminum and the old bearing race if 12 thou. larger than the new ones.I need to weld them up and turn them back down to fit the new race.Do you think that I could use arc rods or use the wire welder?Tig is out of the question as I don't have hi freq. unit.
J. R. Williams
08-30-2009, 08:01 PM
I would bore them out and locktite in a sleeve.
JRW
Ozcad
08-31-2009, 06:34 AM
JRW
loctite may not be the best option as it softens with heating. I would bore hub out an make an slightly over size sleeve heat up the hub so you get a shrink fit and possibly run a weld bead on the edge of the join
radkins
08-31-2009, 10:43 AM
One solution would be to use Loctite Sleave and bearing retainer, it takes longer to set up than Loctite thread locker but it will stand a lot more heat and is even used for air cooled engine cylinder sleeves.
b1vogt
09-07-2009, 07:22 PM
Check with a good bearing supply. They may have a bearing with the same spindle size and a slightly larger o.d. Then you can turn the hub to fit. I have done this and it makes a safe and sturdy repair.
