Job sight pic.
  • jeremy13
    • Apr 2009
    • 792
    Job sight pic.
    I had to take a pic of this engineering not a big tractor but still funny.
    2X6es
  • Bill736
    • Jan 2008
    • 774
    #2
    Folk Fork Lift
    Well, actually I did something similar with my front loader, except I used 1 inch diameter round steel bar for the forks , ground to a point on the ends. The forks lasted long enough to help me clear about an acre of junk left behind by the previous owner of my property, including some smashed car bodies. Eventually, they did bend rather badly, but they probably outlasted the 2 x 6s in your photo !
    • Peter.
      • Mar 2008
      • 2982
      #3
      Timber forks on a loader - I've seen it all now!
      Monarch 10EE 1942
      • andy_b
        • Aug 2003
        • 2401
        #4
        maybe he was lifting big bags of cotton?
        a friend of mine needed to lift some 16' trusses up to a roof he was putting on. he built a gin pole of sorts to stick out from the bucket of his Kubota loader. he bolted three 10' 2x6s together to make a 6x6 and bolted it to the tractor bucket. it worked fine.
        just because that photo looks weird, don't discount the fact that it may have worked perfectly for the intended application.
        andy b.
        • The Artful Bodger
          • Apr 2009
          • 8352
          #5
          andy b.
          I have seen a truck of the tipping kind that carries gravel etc. They had put arms extending forward from the tray then angled in to join in front of the truck and this became their 'yard crane'! Someone had the presence of mind to remove a door so the driver could get in.
          Ashburton, New Zealand
          • rolland
            • Feb 2008
            • 490
            #6
            We used to make them out of motorgrader cutting edges just weld two together one on top of each other and clamp them on a loader bucket. Works good and cheap as the cutting edges are normally thrown away.
