View Full Version : Cutting oil as underwater lubricant?
Timleech
10-04-2009, 06:11 AM
I recently took possession of a little boat which uses 'Neox' or similar underwater oil, gravity fed from a tank, to lubricate the propellor shaft. I've just discovered the tank is empty, maybe has been so for a while. There's no spare oil aboard and I can't get hold of any for a week or so, but I need to do a run of several hours tomorrow so I'd like to know there is some sort of lubricant for the shafting. I've got conventional and synthetic soluble cutting oils here, wondering whether one of those would be better than nothing. Bearing is probably white metal on mild steel.
Any views?
Thanks
Tim
aboard_epsilon
10-04-2009, 06:50 AM
if you don't know Tim
no one does !
in north wales in a place called Rhuddlan ..
on the HTM industrial estate
is a place called "caldo oils"
Tel: 01745 591969
They also have a depot at
Worsley Brow, Sutton, St Helens, Merseyside.
Tel 01744 813535
whatever is nearest ..this company may sell the appropriate stuff ..
i know they sell underwater grease ..and every oil and grease imaginable
all the best.markj
beanbag
10-04-2009, 06:53 AM
grease? marine bearing grease?
sconisbee
10-04-2009, 07:11 AM
Is it a total loss system Tim? where does the waste oil go? On the older boats i've worked on we have used Hydrox 21 but i have no idea who supplies it as it was surplus from an older job, castrol also do an equivelent but both of these are for recirculating oil systems that we used on 100gwt upwards.
Simon
Black_Moons
10-04-2009, 10:34 AM
Somehow I don't think 'cutting oil' as in, one designed to aid in material removal is gonna help you avoid.. material removal.. Just a thought..
Any 'normal' oil is likey much better then no oil, of course removing all traces of the wrong oil later can be a pain. You should probley find out what makes that oil so special. Does it combine with water? Is it heavyer then water so it will sink and displace water if fed from the top of the shaft? Those would be my first two questions.
lakeside53
10-04-2009, 10:39 AM
Soluble cutting oil? I can't think of anything worse... any water getting to the shaft will flush out the oil... I'm sure it supposed to be a heavy "non-soluble" oil
barts
10-04-2009, 12:31 PM
As an emergency substitute, I'd try a good brand of way oil designed to shed water-based coolants - something like vacuoline or the old Vactra oils.
Avoid a detergent-type automotive oil.... if you have any steam enthusiasts nearby, I would think that steam cylinder oil (Mobil 600W) would do in a pinch as well. This is also often used as a lube for worm gears....
- Bart
Timleech
10-04-2009, 12:43 PM
No, it is actually an emulsifiable oil (oil, not grease) which I believe keeps good lubricating properties even with a fairly high water content.
The immediate panic is over, as there was enough oil in the 'used' tank to drain off & refill the supply tank. It's not a system that I'm totally familiar with, as it has a return pipe to a drain tank which has to pass through a swan's neck nearly the same height as the supply tank. Other vessels I've come across using Neox oils etc. have what is basically a 'total loss' system similar to the simple greased glands, but with an oil tank instead of a greaser.
I'll be able to source a proper supply of the right oil during the next week or two.
Thanks
Tim
