View Full Version : Anti-seize for Aluminum on Aluminum
beanbag
10-17-2009, 02:55 AM
OK, so I cut some external and internal threads, and now want to connect them. I cut the threads so there is a little wriggle both radially and axially. I did a google search, but didn't find any mention of what anti seize you should use for aluminum on aluminum.
10-17-2009, 03:23 AM
Bostik Never-Seez, Heavy Metal Free grade. It's designed to prevent galling with soft metals. The lack of metal fillers prevents dissimilar metal corrosion.
speedy
10-17-2009, 03:55 AM
chesterton nickel compound. I am on my last tin of the stuff; nearly gone.
http://kscdirect.com/item/CHE%2B82359/PIONEER%2BINDUSTRIAL%2BCORPORATION_82359%2BCHESTER TON%2BNICKEL%2BANTI-SEIZE%250A
JoeFin
10-17-2009, 10:16 AM
I totally agree with Evan, but it really depends on your application
Metal Free grades are for providing error free torgue and complete seating of the materials. Nickle compounds are used in pipe fitting and provide some lubercateing qualities but at the same time provide a metal filler to fill tiny micro leaks. They will gall and are "Single Use"
beanbag
10-18-2009, 08:16 PM
Thanks for the suggestions
