View Full Version : 5c spindle taper lathes
krems
10-18-2009, 10:05 PM
Is it posible to get a 5c spindle taper on a lathe other than a hardinge hlv or clone. I like the idea of a 5c taper spindle but would like a larger machine...somewhere in the 13 x 40 size. Is it because most machinists like larger spindle diameters. My thoughts are that any 5c collet chuck or nose wont have the inherent accuracy as a 5c spindle. Any thoughts
Krems
gr8life
10-18-2009, 11:34 PM
Buy the lathe that will work for the jobs you do, then add a set thur 5C collet chuck.
just my $0.02
ed
barts
10-18-2009, 11:49 PM
Seems to me that unless all you do is work to very great precision (one or two tenths) that the advantages of a larger spindle bore, easily available chucks, etc, far outweigh any additional run-out caused by a MT-5 -> 5C adaptor.
- Bart
10-19-2009, 12:14 AM
Just make the adapter IN the lathe....... and mark it for rotational position. Then it will be as accurate as your bearings when put back in that position.
macona
10-19-2009, 02:00 AM
You could find yourself an old Rivett.
Otherwise a spindle nose and a drawbar if your through hole is big enough.
Last resort is a collet chuck.
