View Full Version : To: oldtiffie, About Tooling inserts.
Black_Moons
10-24-2009, 04:26 PM
Hi oldtifflie and others, Im wondering about oldtiffles recent post and the picture http://i200.photobucket.com/albums/aa294/oldtiffie/Lathe_misc/I-Fanger3.jpg
What kinda holder/toolbits are those? iv never seen that kinda insert system before, I assume they are HSS inserts.
oldtiffie
10-24-2009, 10:15 PM
They are made by a Swiss firm and are bloody expensive.
I don't know what the tool-steel is but its reasonably easy to grind )by hand to the template) and is tough and holds a very good edge on some tough material in the lathe.
The corrections for tool form and shape/profile for the tool rakes and clearances are applied as part of the manufacturing process.
Here is the parting tool "at it" in a situation that might have made the job pull out of the chuck or a TC parting tip fail or fracture. I just "went for it" and ploughed it in.
http://i200.photobucket.com/albums/aa294/oldtiffie/Lathe_misc/Part_off4.jpg
http://i200.photobucket.com/albums/aa294/oldtiffie/Lathe_misc/Part_off1.jpg
The only limitation is the tool travel/range.
I just tack-welded it to a bit of spare rectangular section steel tube that I had and then finished it off on the band saw - then recovered the off-cut and RHS by grinding out the tack welds.
I guess I can't expect (too) much (or any at all?) from a Chinese lathe and chuck and a European tool though.
Must have been just a fluke or good luck - I don't recall it being a "set-up" either - must be poor or selective memory!!!
Black_Moons
10-25-2009, 04:23 PM
they do look like pertty intresting HSS insert system... to bad about being expensive :(
