View Full Version : Removing & Installing 3/8" Dovetail Front Sight
JMI
10-28-2009, 01:08 AM
I have a old Remington 510 single shot that needs replacement of the front sight. The sight is dovetailed directly to barrel - not on a ramp. Any plans/drawings for a homemade tool using threaded jacking piece or should I just drive/drift the old one off and drive/drift the new one on with a wood or brass dowel?
A threaded tool would also be nice to fine adjust front sight for windage.
Thanks
Jim
JCHannum
10-28-2009, 09:59 AM
The sight can be removed using a drift, driving from left to right.
This is a sight pusher I made if that suits you. It is 1" wide X 3-1/2" long X 2" high. It need not be elaborate, the fine thread assists in fine adjustment for windage.
http://i320.photobucket.com/albums/nn351/jchannum/P1070380.jpg
mcskipper
10-28-2009, 03:43 PM
Good looking pusher!
Brass & alum is just right, no marks from that.
Just remember that on most guns, in from the right out from the left.
As you would hold the gun.
JMI
10-28-2009, 08:54 PM
Thanks for the replies. I like that pusher.
Jim
38_Cal
10-29-2009, 11:52 AM
The problem with sight pushers and round barrels is that there is nothing to clamp to/against that won't keep the pusher from moving when the pusher pad contacts the sight. On a sight in a ramp, or even an octagon barrel, you've got a flat surface to brace against. Best bet on a sight directly in a round barrel is a padded bench vise and a brass tipped punch with an eight ounce ball-pein hammer behind it.
JCHannum
10-29-2009, 12:05 PM
Using a pusher on a round barrell pretty much requires that either the barrel or the pusher be clamped in a vise to prevent turning. The hammer and drift are more expedient. The pusher does provide a more controllable means of adjusting a sight for windage.
I made the pictured pusher to install and adjust a front sight on a ramp to prevent damaging or loosening of the ramp. It did serve the purpose, but now resides unused in my gun stuff drawer.
Highpower
10-30-2009, 03:52 PM
JCH -- What are you using as a bearing surface between the brass pusher and the steel screw. Does the brass have a shoulder that it bears on, or maybe a steel ball in the center of the screw hole?
Just curious. I hate it when the brass tends to turn with the screw under pressure.
JCHannum
10-30-2009, 06:39 PM
The screw is 3/8", the brass pusher is 1/4" with a 3/8" flange to keep it from falling out. Pushing pressure is low enough that the pusher does not turn. If it were a problem, the end of the screw could be reduced or turned to a point to reduce the tendency.
