View Full Version : Baalcing grinding wheels
loose nut
10-29-2009, 10:10 PM
Do grinding wheel flanges that have built in adjustable wheel balancing weights, for static balancing, have them on just one side or both sides.
Glenn Wegman
10-29-2009, 10:23 PM
I've only ever seen them on one side, but I imagine it may be possible to dynamic balance a wide wheel such as a centerless grinder wheel.
lazlo
10-30-2009, 07:58 AM
The Spoko flanges I've seen only have the sliding balancing weights on one side. Like Glenn says, unless the wheel has a deep cross section, that should be fine.
loose nut
10-31-2009, 02:17 PM
All I needed to know, thanks.
