jgourlay
11-02-2009, 08:24 AM
Gents, this is off topic, but I'm posting it because this is the only place on the web where I think folks have the expertise. So, please forgive the bunny trail.
I have a Dewalt D735 thickness planer. Basically, it's a large box with a long rotating cutter supported over a flat surface by four stationary ball screws. There is a drive belt that goes around all 4 ball screw nuts. This belt is driven by a handwheel on the outside of the upper box and the nuts are in the box.
Turning the handwheel drives the belt. The belt drives the ball-screw nuts, which makes the box go up and down. It's critical to note that the function of this arrangement to allow the box to ascend and descend in in perfectly coplanarity with the base plate.
Friday, I went to fixing something that caused me to have to take off the base plate. While considering another issue, my evil left hand started brainlessly twaddling with one of the posts. So, note now that I have the box upside down with all four posts sticking up--something like a dead armadillo. Because the posts are not now in the base plate, they are free to turn.
And, of course, as soon as I turned this post the distance between the bottom of that post and the bottom of the other three posts is not what it's suppose to be. So I put it all back together and it's immediately obvious something very wrong because that hand wheel won't turn without a lot of force and I can see the box is now out of parallel with the base plate.
What makes this harder is that the post go into holes in the base plate and you really have hammer to drive them home: it's a very tight fit. Which means I can't just flip it over and hand rotate the ballscrews down until the touch a registered surface.
Now, I thought about putting a gauge bar onto the cutter head and stacking the base plate on that and threading the ballscrews to location. But that turned out badly because there was simply no way to hold everything together to allow the alignment: it was frustrating and ugly.
Do you have some high-speed/low-drag methodology to solve this kind of issue on your machine tools? Any suggestions beyond "take it back to Dewalt and fess up?"
