View Full Version : A Little More Work in my Vault Lock
chriskat
11-05-2009, 09:18 PM
You can't really see too well in the picture below but I broke not one but two 2-56 taps off in the receiver. The screws were two of four to be used for hold downs. I gave up trying to get them out and modified the plan to used just one srew per hold down and a 1/16" pin.
http://home.comcast.net/~chriskat/Vault%20Lock%20Rifle/DSCF4812%20%5B640x480%5D.JPG
The picture below has the hinge pin for the action installed in it's slot.
http://home.comcast.net/~chriskat/Vault%20Lock%20Rifle/DSCF4814%20%5B640x480%5D.JPG
And here are the hold downs. They could also be called keepers I suppose, they keep the hinge pin in place.
http://home.comcast.net/~chriskat/Vault%20Lock%20Rifle/DSCF4815%20%5B640x480%5D.JPG
chriskat
11-05-2009, 09:24 PM
And here it is with the keepers sitting where they belong.
http://home.comcast.net/~chriskat/Vault%20Lock%20Rifle/DSCF4816%20%5B640x480%5D.JPG
When it's finished the stock bracket will overlap the keepers and will be held in place by at least 2 10-32 screws so I think/hope this will be ok.
Below is the trigger assembly roughed out. I decided to use a tang off the rear of the trigger guard as the operating lever. It will be similar to a TC contender but longer. When finished I'll bend it into an arc.
http://home.comcast.net/~chriskat/Vault%20Lock%20Rifle/DSCF4818%20%5B640x480%5D.JPG
I'll post more pics as I go along.
Hopefully I won't make too many more mistakes. The night I broke the taps was not a good one, I broke about 4 drill bits first. Should have quit after that, it was an omen.
Ken_Shea
11-05-2009, 09:33 PM
Well, you are right, cant really tell in the picture but the explanation is enough to know that it had to be a bummer, at least it was thoughtful enough to break in the same place on both, nice recovery BTW.
Do you have a link to a completed Vault Lock rifle? not familiar with them.
Bob Ford
11-05-2009, 11:05 PM
Ken
http://bbs.homeshopmachinist.net/showthread.php?p=438079#post43807
Chriskat
That trigger housing will take a lot of work, but should turn out fine. The first few seem to have little problems. I used 4 - 10/32's per mount front and back.
Rock steady.
Bob
chriskat
11-06-2009, 06:37 AM
Bob,
What's the butt plate on your rifle? I hadn't seen the finished pictures before, very nice.
Jeff
Bob Ford
11-06-2009, 10:22 AM
3/16th Aluminum plate.
Bob Ford
11-21-2009, 05:42 PM
Jeff,
On page 40. Fig. 3-27. Extractor housing there are two dimensions for the ejector hole .505 down from the top and .685 measured from the front. The .685 dimension is in error. I first believed it should be .585 and used that dimension on my first actions, But believe it could be from .585 to .605.
Hope you have not drilled the holes in the housing already.
Bob
chriskat
11-22-2009, 08:08 PM
Thanks very much, I haven't. I'll check carefully before drilling. Is there something that would tell me where it should be drilled in the range you mentioned?
Incidentally, I was in San Jose week before last on business. You anywhere near there?
Jeff
Bob Ford
11-23-2009, 06:47 PM
Jeff,
The dimension given in the book will put the hole partly in the groove if made as shown P> 35 Fig.3-8.
The dimension I gave will work fine you have .020 range to play with.,
You were about 7 - 71/2 hrs drive south of me. I am about as far north and west as you can get and still be in California.
Bob
