View Full Version : Atlas shaper table extention
johnnyd
11-09-2009, 01:42 AM
Does anyone have any pictures of the extention table for the 7" Atlas shaper?
gvasale
11-09-2009, 08:17 AM
have you tried the Yahoo shaper group?
Too_Many_Tools
11-09-2009, 11:51 AM
Has anyone built one for the Delta shaper?
HarryG
11-09-2009, 11:03 PM
Is that one that Atlas sold or aftermarket?
johnnyd
11-09-2009, 11:11 PM
Mine has S7 436 in raised numbers cast into it.
I had assumed that it was an original piece?:confused:
My original reason for asking was to see how they were mounted.
Mine has 3 holes drilled in each side, but there are no holes tapped into the table.
http://i1010.photobucket.com/albums/af226/johnnyd1/t1.jpg
http://i1010.photobucket.com/albums/af226/johnnyd1/t2.jpg
http://i1010.photobucket.com/albums/af226/johnnyd1/t3.jpg
HarryG
11-09-2009, 11:31 PM
With that number, I'd also guess it was from Atlas. I've never seen one.
Can you post pics?
johnnyd
11-10-2009, 11:20 AM
New pictures added---bump:)
JCHannum
11-10-2009, 11:52 AM
The table is an Atlas option that is rarely encountered. It bolts to the front of the table, holes must be tapped to accomodate it. I suggest mounting it a tad high and machining it in place to match the existing table with the shaper itself.
johnnyd
11-10-2009, 06:11 PM
Thanx Jim...Thats exactly the information I was after.
"Make Swarf & Prosper".....John
speedy
11-10-2009, 07:55 PM
It might be worthwhile to locate it with dowels.
Dawai
11-10-2009, 08:40 PM
No, but I made a add on table top for mine from 1" thick metal, drilled on the cnc to match the SOUTHBEND shaper table. Not sure I got a picture or not, it ain't nothing but a slab with holes in it.
I needed a way to mount the 4" indexer-stepper to cut gears and xl pulleys.
Still not completed, I started facing it off on the shaper, got on other projects.
That lil shaper keeps pulling my projects out of the gutter.. still earning it's keep around here. I did cut some UHMW slides on it, tried to square them, in the vice they keep shifting/deforming and making paralleograms instead of rectangles thou..
