View Full Version : Rockwell 11" Reeves Drive Sticking
rwilliams
11-09-2009, 11:25 AM
The center section of the large aluminum pulley set binds and will not slide freely on its shaft (it can be pressed off) thus changing speeds is very difficult.
If any one has experenced this how did you fix it?
The pulley has a center bushing made of a dark nonmetallic material. Does anyone know what it is and the best way to open it up a bit if that is the solution?
Thanks,
Bob W.
