View Full Version : Non-pullout spring collet systems
chris2a2
11-10-2009, 09:21 AM
If I use an end mill cutter with a uniform shank, will it damage a spring collet system that uses a non-pullout button on the inside diameter of the collet?
dfw5914
11-10-2009, 11:11 AM
Yes,it will likely damage the locking element and the internal taper of the collet holder. The anti-pullout element can usually be removed from the collet allowing uniform shank tools to be gripped.
http://i112.photobucket.com/albums/n188/pmhurco/nov002a.jpg
