View Full Version : Question for the UK members
ckalley
11-16-2009, 11:06 AM
I came across this at work.... from a company in the UK. They specify a 13.6 pitch gear. I looked at a bunch of references and can't find any thing in module or customary sizes that are even close. Any one got an idea?? Thanks
Craig
Timleech
11-16-2009, 12:09 PM
Craig
What's it in? is it something exotic where every micron of space has to be used to best advantage, justifying tooling up for a 'special'? Or just an instance of being awkward so you have to go back to the makers for replacements?
Just a thought, is the physical size right for a gear between 13 & 14 DP? Or is there a chance it's an old design & actually misread 13/16" Circular pitch (quite big, about 7 Module)?
Tim
oil mac
11-16-2009, 12:11 PM
Craig,
Of hand without going through my textbooks, I also find this a little bit of a puzzle, It sounds to me to very much be a non standard item, Do they specify metric or imperial measurement? If it is circular pitch, which is sometime just referred to in old drawings as say 2"pitch, i could understand, If that is the case 13.6 would be a humungous size of tooth, I dread to think the dia of the gear would be :eek:
Could it be a mistake in communications? can you ask them for guidance
ckalley
11-16-2009, 12:41 PM
oil-mac
The trouble is I'm dealing with sales people and buyers (purchasing agents). No help there....
From what I understand it's something on a rail car. I was given a drawing of a wheel with slots plunged thru the OD that are aprox. 6mm wide. I can't figure where the 13.6 comes from....
Thanks
Craig
Timleech
11-16-2009, 01:00 PM
oil-mac
Thanks
Craig
So is it an actual (involute) gear, or something different? Any ideas on OD or number of teeth?
Tim
John Stevenson
11-16-2009, 01:39 PM
Probably a dyslectic designer who meant 316 stainless ?
David De'ath
11-17-2009, 12:51 PM
John, please remember that dyslexics are teople poo
