View Full Version : Two transmission assembly stands I just built.
winchman
11-24-2009, 06:02 AM
The fellows in AgTech needed some more transmission assembly stands like this:
http://img.photobucket.com/albums/1003/winchman/transmissionassemblyfixturesandt-3.jpg
So, I put these together:
http://img.photobucket.com/albums/1003/winchman/transmissionassemblyfixturesandt-4.jpg
We didn't have any large-diameter round stock or heavy-wall pipe, so I made the smaller shaft receptacles out of the pipe we had on hand.
http://img.photobucket.com/albums/1003/winchman/transmissionassemblyfixturesandt-5.jpg
I cut short lengths of pipe into segments, strapped them around a round form with two layers of aluminum foil in between. After the segments were welded together lengthwise, I pressed the form out. The foil made that job MUCH easier.
http://img.photobucket.com/albums/1003/winchman/transmissionassemblyfixturesandt-6.jpg
On the larger receptacles, I welded the segments inside a piece of pipe before boring it to size.
If I had had the right materials from the start, it would have been just plain boring.
Roger
rockrat
11-24-2009, 10:18 AM
Nice work. I wish I could get a customer a day wanting things like that.
rock~
