View Full Version : Is Tap Magic a "green" product?
goose
12-16-2009, 09:41 PM
No, that's not what I mean... I'm currently using Tap Magic "Pro-Tap" and I'm getting green (corrosion?) mould on everything. Brass, the QC tool post, some tooling, and even the sling line behind the lathe. The wash pot I use (mineral spirits) is definitely tainted green. I can only trace this to the use of this product, before I was using the other Tap Magic, the one that smells strong.
Has anyone else experienced this?
Thank you,
Gary
12-16-2009, 09:49 PM
Check the label for Chlorine based solvents.I used to use the stuff,but quit since sulpher based threading oil does the same job for 1/10th the price.
goose
12-16-2009, 09:55 PM
Checked,
"This product does not contain Thriclor 1-1-1, Sulfur, Chlorine or Silicon"
I'll change out next time I order anyways, still entertaining theories or conjecture. Thanks,
Gary
Carld
12-16-2009, 09:56 PM
I have a can for aluminum and a can for steel and have had them for many years. I seldom use them but I have never had the problem you describe.
Black_Moons
12-17-2009, 02:17 AM
First thing that comes to my mind when you say green is copper.
Any corroding pipes driping water/condensation above your lathe?
I guess pure cutting oils could go rancid.. those diluted ones do.
Try pouring out a sample of the stuff from the bottle onto some metals and see if anything happens in a few days... If the bottle is 'infected' with something id throw it out, unless your willing to cook it or something. (suspend bottle into boiling water? idealy outside on an electric hotplate on a long extention cord)
Not sure what you'd use to kill the stuff off around your lathe if its mold.
Marc M
12-18-2009, 04:08 AM
Check your shop for Chinese drywall ! :D
OK, I'll go back to work now :(
Your Old Dog
12-18-2009, 06:34 AM
It turns the paint on a 1965 SouthBend to mush.
CLARKMAG
12-18-2009, 10:52 AM
I heard they were making a new Tap Magic that is less toxic.
I can sense when a chemical is getting me "high".
Paint with Toluene or lacquer thinner are much worse than Tap Magic.
Tap Magic reminds me of Naphtha lighter fluid.
http://www.tapmagic.com/MSDS_TMO.htm
goose
12-18-2009, 07:29 PM
I'm gonna try isolating the problem, starting with new tupperwares for the "parts washer"
Whatever it is, it seems it most affects brass.
Gary
