View Full Version : 50HP Head Stock!!!
jeremy13
12-21-2009, 10:21 PM
In my quest for a CNC mill I went and visited a shop in Houston. They wear assembling a Russian lathe. Man that thing was big!! Six foot swing 50hp headstock and 15hp cross slide mill attachment. Only got one Pic.
http://i48.tinypic.com/331khh3.jpg
Black_Moons
12-21-2009, 10:28 PM
A1-20 mount I assume? lols.
deeman
12-21-2009, 11:11 PM
I never will understand why people will stand there with one hand trying to balance a heavy piece of machinery underneath an overhead crane.i
A.K. Boomer
12-21-2009, 11:25 PM
Its called guiding it...
.RC.
12-22-2009, 12:13 AM
50hp does not seem like much for a 6ft swing...Looking at the size of the headstock it should be 150hp...
Doozer
12-22-2009, 12:23 AM
Yeah, but it is at like, 4 RPM, so torque is off the map!
--Doozer
Black_Moons
12-22-2009, 01:30 AM
deeman: its because watching one guy holding onto it is less scary then watching it spin around.
deeman
12-22-2009, 05:04 AM
Black_Moons...a 15 foot piece of rope works for me until it gets close to the floor.
Bguns
12-22-2009, 05:41 AM
Ropes are part of safe lifting.. but only part... You can't push with one....
Putting track frames on a D9 Cat is not a place for a 15 ft rope...
Too many surfaces to slide up, over, under, and align...
Keeping away from gravity zone :) is about all you can do...
I try not to lift anything more than 2 inches higher than needed, so less distance to fall... Can't plan on which corner of a load may break free and which direction it will go... so I just try to keep a 45 degree angle clear zone around work....
gda
12-22-2009, 06:44 AM
Besides keeping the thing from spinning I like to keep a hand on the load so that I always know where it is to my body. I won't accidently lose track of where it is and get part of my body under it. Also, if it starts to fall my hand is on it to feel it first, then I'll be able to push myself away (or have the load push me away if I lock my arm).
digger_doug
12-22-2009, 07:05 AM
--Doozer
Torque is not everything doozer...it takes h.p. to remove metal
efficiently.
Exactly, the 54" bullard I used to run had at least 50 h.p. maybe 75 h.p.
j king
12-22-2009, 09:20 AM
I think this has 50 squirrel power. Maybe a couple more after some R&R time between breaks.
http://img.photobucket.com/albums/v24/ikimjing/Jim004.jpg
